11 Homemade Face Scrubs for Glowing Skin
A healthy skin is what makes you look glamorous and elegant. Good Diet, Proper Exercise, and Beauty Sleep all these contribute in giving a naturally soft and glowing skin. Also, the integral keys to a healthy skin are cleansing, scrubbing, toning and moisturizing your skin from time to time. Cleansing and Scrubbing help remove the dead cells and removes dirt, oil, and sweat from it (1). Toning helps you with a wonderful skin texture. Moisturization, as the name suggests, provides proper moisture and gives you a soft, smooth skin. All these skin care techniques work in tandem to give you a soft, velvety smooth, glowing skin. A perfect skin care routine needs to be followed to get a glowing skin forever. In this post, we will be highlighting the scrubbing part and 11 natural homemade face scrubs for Glowing Skin.
How do Scrubs Work On Your Skin?
Just like Cleansing, Toning and , Moisturizing, Scrubbing also acquires an equal amount of significance in your beauty regimen. Exfoliation of the skin can prevent many skin problems and give you a soft, smooth and glowing skin. Proper use of homemade face scrubs and body scrubs can do wonders for your skin (2).
A few ways how scrubs work on your skin are:
- Scrubbing pulls out all the dirt that has accumulated in your skin pores . It gives a clean skin, free of all dirt, and sweat.
- Flaky skin looks obnoxious. It also gives rise to dry patches and allows dead cells accumulate over time.
- It helps to remove dead cells which otherwise make your skin look lifeless and dull.
- It adds a glow to the skin. Exfoliation can actually make your skin glow in no time.
- Scrubbing can also help you do away with dark patchy skin. It helps remove dark patches on your skin.
- Scrubbing can also help remove the acne scars. Certain face scrubs deal with the scars left behind by acne and help to remove them.
- Ingrown hair is a problem faced by most people and scrubbing is the best possible solution for this problem. Scrubbing helps prevent ingrown hair.
- Scrubbing helps give you a smooth skin. It not only gives you a velvety smooth skin but also makes your skin soft and well-nourished.
- Scrubbing helps to improve the texture of your skin.
- Scrubbing gives you a clear skin.
- Scrubbing helps you get done with these and gives you a clear complexion in return.
1. Coconut Body Scrub
Coconut body scrub help in removing all dirt from your skin.
Ingredients
- 1/4-1/2 cup sugar (Granulated ),
- 1/2 cup Coconut oil.
Method
- The oil should not be heated as it might melt the sugar.
- Combine the ingredients to form a coarse paste.
- Cleanse your skin and apply the paste formed to it.
- Spread the paste uniformly and use your finger tips to massage the mixture, in circular motions, on your skin.
- Keep massaging the mixture on your skin for 5-10 minutes, giving each part 1-2 minutes to exfoliate.
- After applying the mixture uniformly keep it for few min, wash the mixture off using lukewarm water.
- It not only exfoliates your skin but helps remove make up.
- You can use this 2-3times a week.
Coconut Body Scrub
2. Oatmeal Face & Body Scrub
The oatmeal body scrub is one of the best homemade body and face scrubs for glowing skin.
Ingredients
- ½ cup Oatmeal (Uncooked ),
- A ½ cup Brown Sugar,
- ½ cup Honey,
- ¼ cup Jojoba Oil,
- 3-4 drops Lavender Essential Oil,
- 4-5 drops Geranium Essential Oil,
- 3-4 drops Frankincense.
Method
- Grind the dry ingredients till you get a fine powder out of it and then mix the liquid ingredients into it.
- Mix all other ingredients till you form a coarse paste.
- By using a soft cleanser , clear your skin.
- Apply the mixture of past on your skin.
- Spread the paste uniformly and use your fingers to massage the mixture, in circular motions, on your skin.
- Wash off with lukewarm water.
- It also helps and soothes troubled skin.
- You can use this twice a week.
Oatmeal Body Scrub
3. Turmeric Face Scrub
Ingredients
- 1 tablespoon Rice powder,
- One tablespoon Gram powder,
- 1 teaspoon turmeric, Milk.
Method
- Mix the ingredients in a bowl. Use a very small amount of milk to make a thick paste.
- Moisten your face and neck and apply the paste.
- Massage it for 3-4 minutes with your fingertips. Make sure you follow a circular motion.
- Apply some milk to it to make a smooth thin paste.
- Apply this smooth paste on your face and neck.
- Leave it for some time around 15 to 20 min and then wash off.
- This scrub helps you recover from skin problems like sun tan, dark spots etc.
- It is also helpful in treating acne scars and leaves your skin glowing and spotless.
- This is best suited for a dry and normal skin. In case of oily skin, use rose water instead of milk.
Turmeric Face Scrub
4. Milk Cream Scrub
This is best suited for a dry and normal skin. In case of oily skin, use Yogurt instead of milk.
Ingredients
- Milk cream,
- Oatmeal.
Method
- Soak oatmeal (raw one) in lukewarm water for 1-2 minute.
- Extract the excess water and then add 2 tablespoons of milk cream to the soaked oatmeal.
- Mix them to form a thick paste.
- Massage the paste into the moist skin for 3-4 minutes.
- Massage uniformly in the circular motion.
- Wash off the paste with lukewarm water.
The milk cream scrub gently removes all pollutants without stripping away the skin essential moisture leaving your skin nourished and healthy.
Milk Cream Scrub
5. Sea Salt Body Scrub
It helps improves the blood circulation.You can use this once a week for dry skin, twice for normal skin and thrice for oily skin.
Ingredients
- 1 cup Sea Salt,
- ½ cup Olive Oil,
- 5-15 drops of An Essential Oil of Your Choice.
Method
- Combine all the ingredients to form a coarse paste.
- Cleanse your skin and apply the paste to it.
- Gently massage the paste into your skin using your fingers.
- Massage for 5-10 minutes, giving each part 1-2 minutes.
- Rinse using any hydrating body scrub and lukewarm water.
Sea Salt Body Scrub
6. Papaya Face Scrub
It cleanses the pores, moisturizes the skin and removes skin blemishes leaving your skin flawless.This is best suited for a dry, normal and sensitive skin.
Ingredients
- Papaya,
- 3 tablespoons Sugar.
Method
- Blend a few ripe papayas into a smooth paste.
- Add 3 tablespoons of sugar to the paste and mix properly.
- Cleanse your face and apply the paste to your moist skin.
- Massage the scrub for 2-3 minutes.
- Leave the scrub on your face for 15 minutes and then rinse using cold water.
Papaya Face Scrub
7. Sandalwood Face Scrub
This face scrub leaves your skin soft, smooth and silky.This is best suited for all skin types.
Ingredients
- Sandalwood powder,
- Saffron,
- Rose petals,
- Rose water.
Method
- Mix 2 tablespoons of sandalwood powder, 1 teaspoon of powdered saffron, 2 tablespoons of dried rose petals’ powder and a few drops of rose water to form a smooth paste.
- Wet your hands and apply the paste to your skin.
- Gently massage the paste on your skin in small circular motions.
- Leave the scrub for 10 minutes and then rinse using cold water.
Here is an amazing video from iamvanessae
8. Yogurt Body Scrub
If you have dry skin and need to exfoliate, this is the body scrub for you.
Ingredients
- 1 tbsp. Yogurt,
- ¼ cup Olive Oil,
- 1 tsp Honey,
- 3 tbsp. Granulated Sugar
Method
You can use this 2-3 times a week.
Yogurt Body Scrub
9. Almond Face Scrub
It intensely exfoliates and detoxifies the skin and then moisturizes it removing all the dead cells, dirt, blackheads and whiteheads. This is best suited for a dry and normal skin.
Ingredients
- 4-5 Almonds,
- 1/4 cup of warm milk.
Method
- Soak the almonds in a 1/4 cup of warm milk.
- Leave it like that for an overnight.
- In the morning, blend the soaked almonds into a semi-smooth paste.
- Cleanse your face. Apply the paste on the moist skin.
- Gently massage the scrub for 2 minutes using your fingertips. Rinse using lukewarm water.
Almond Face Scrub
10. Coffee and Sugar Scrub
This helps fight cellulite, gets rid of dead cells and keeps the skin healthy. This can be used 2-3 times a week for a smooth and glowing skin.
Ingredients
- ¼ cup Ground Coffee,
- ¼ cup Sugar,
- 2 tbsp. Extra Virgin Olive Oil,
- 3 Vitamin E Capsules.
Method
11. Orange Peel Face Scrub
This is best suited for an oily and normal skin. This can be used 2-3 times a week for a dry and sensitive skin.
Ingredients
- 2 tablespoons dried orange peel powder,
- 2 tablespoons honey,
- 1 tablespoon salt.
Method
- Mix all ingredients in a bowl.
- Cleanse your face and neck with warm water.
- Apply this facial scrub on your moist skin.
- Massage the scrub on your skin in clockwise and anti-clockwise motions for 3-4 minutes.
- Mainly scrub the oily or the T zone areas of your face to remove the blackheads and the whiteheads.
- Rinse using lukewarm water.
- Its anti-aging and soothing properties leave the skin extra soft and glowing.
Precautions to be taken
- Cleanse your face and neck properly before applying any face scrub.
- Remove any cream or lotion or makeup that was applied earlier before applying the scrub.
- Take a hot shower or a steam bath to clean and open up your pores before applying body scrubs.
- Before applying any scrub, do a Patch test on a little area of your skin and wait for 10-15 minutes. If the scrub causes any irritation or rashes on your skin or if the particular areas itches, wash off the mixture immediately and rinse with cold water.
- Use gentle circular motions while massaging the scrub on your skin. Do not use harsh strokes. Remember, your skin is delicate and requires tender strokes.
- In case of sunburns or rashes, avoid using scrubs.
- In spite of buying artificial products rely on home remedies to get glowing skin.
- Try some yoga asanas to get a natural glow.
Well, human skin is pretty ethereal and sensitive. In order to maintain a beautiful skin, one should take proper care of it. Only proper care can add the glow to your skin and give you that vibrancy and make you look lively throughout your day. Apart from the homemade scrubs, a proper diet, regular exercise and adequate sleep work well for your skin.
