How to Get Rid of Pimples Overnight | 21 Proven Home Remedies
How to Get Rid of Pimples Overnight is this your question? Every one of us hates pimples and loves smooth glowing skin. But, because of the stress, unhealthy diet, lack of exercise, pollution and improper lifestyle, many people face this problem. You can see a long queue in the dermatologist’s clinic. It definitely cures pimples but for a long run, the intake of those medicines is harmful. In this post, we have shared 21 proven home remedies that you can do to get rid of pimples quickly without any harmful side effects (1).
Skin Science
Sebaceous glands produce and secrete a waxy substance called sebum. These glands are present in the skin of the entire body, except in the soles and palms. The sebum keeps your skin healthy by maintaining its oil balance. When these sebaceous glands have any abnormality in them, the pimples develop. Pimples or acne are the skin inflammations or lesions that occur due to bacterial infection. They are also called papules, pustules, zits, and spots (2).
Cause of Pimples
Pimples can occur due to numerous reasons. Here are the leading causes of pimples.
- Heredity: A genetic problem may give rise to pimples throughout your life.
- Puberty Pimples: Both boys and girls can face pimples when their body undergoes physical changes.
- Bacterial Growth: Sebum gets blocked which create conditions suitable for bacterial growth.
- Build up of dead skin cells.
- Testosterone sensitivity
- High Glycemic foods
- Oily Food
- Frequent Traveling
- Sensitivity to Skincare products
- Stress
- Not removing makeup
- Rubbing skin
Whatever be the cause, they should be treated immediately as the untreated acne can leave scars that are hard to remove.
Types of Pimples
Pimples that appear alike on the surface can be of different types underneath. Determining the kind can help you treat them suitably.
- Whiteheads: These are the white spots that occur on the oily skin.
- Blackheads: Blackheads develop when the pores are pressed to push their material out. Moreover, they can also be caused due to dirt, bacteria, and build up of dead skin cells.
- Pustules or Nodules: These are caused due to infection and inflammation of skin tissue neighboring the clogged pores.
- Cysts: These are deep pimples that are filled with pus.
How to Get Rid of Acne Overnight?
1. Essential Oils
You can use essential oils such as Frankincense, Peppermint, Lavender, Lemon, Lavender, and Grapeseed.These oils have antifungal and antibacterial properties along with the antioxidants to eliminate the infection and heal the pimples quickly.
How to Use?
- Clean the affected area and dry it.
- Take a cotton ball and put few oil drops on it.
- Apply to the affected area directly.
Precaution
Individuals who have sensitive skin, need to do a patch test before applying any essential oil to their skin.
2. Epsom Salt
Epsom salt cleanses the skin. It does so by exfoliating the dead cells and killing the bacteria. Besides, it rebalances the pH levels of your skin.
How to Use?
- Add 1 tsp Epsom salt to the water. Mix well.
- Dip a cotton ball into the Epsom salt water and dab on the affected skin.
3. Apple Cider Vinegar
The mild acids in apple cider vinegar normalize the oil production of the skin. Moreover, being an antimicrobial agent, it sterilizes the skin by killing the bacteria. It provides the perfect answer to your question How to Get Rid of Pimples Overnight.
How to Use?
- Mix the water and apple cider vinegar in a 1:1 ratio.
- Apply the diluted vinegar on the affected area using a cotton ball.
- Rinse it off with cold water after few minutes.
Apple Cider Vinegar
4. Milk of Magnesia
Milk of magnesia acts as a disinfectant and also removes excess oil from your skin.
How to Use?
- Put few drops of milk of magnesia on a cotton ball and apply its thin layer to the affected area.
- Leave it for 30-40 minutes. Then rinse it with cold water.
5. Baking Soda
Baking soda soothes the skin by reducing inflammation. It also dries out the pimples and normalizes the skin pH.
How to Use?
- Make a paste by adding water to 1 tsp baking soda.
- Apply this over the pimples with your fingers.
- Leave it for about 5 mins. Then rinse it with warm water.
6. Coconut Oil
Coconut oil has antibacterial properties. It heals, hydrates, and helps the skin cells regenerate.
How to Use?
- Lightly warm up the coconut oil.
- Apply the warm coconut oil to the affected area with your fingers.
- Leave it for few hours. Apply twice a day.
Coconut oil
7. Fish Oil Pills
Fish oil contains omega-3 fatty acid that reduces skin inflammation and speeds up the healing process.
How to Use?
- Take one fish oil capsule daily or pop it open to apply the oil on your affected area.
- Continue for few months until the acne is controlled.
8. Garlic
Garlic possesses antibacterial properties that help fight acne.
How to Use?
- Make a paste of 2-3 garlic cloves by adding a little water.
- Apply the paste to the affected surface.
- Leave it for 10 minutes and then wash off.
9. Vaseline
Vaseline keeps the skin hydrated. It also improves the appearance of fading away acne blemishes.
How to Use?
Apply a thin layer of vaseline on and around the skin having pimples.
Precaution
Do not use this remedy if you experience the occurrence of pimples more often.
Here is an informative video from Shruti Arjun Anand
10. Honey
Honey is a natural antibiotic. It removes pimples easily and keeps the skin healthy.
How to Use?
- Apply raw honey to the affected area with your fingers.
- Leave it for 30-40 minutes and then wash off with water.
Honey
11. Ice
Ice provides a soothing relief quite fast. It reduces the swelling and shrinks the acne.
How to Use?
- Wrap an ice cube or crushed ice in a clean and soft piece of cloth.
- Apply it over your pimples and leave it on 2-3 minutes.
12. Toothpaste
Toothpaste possesses antibacterial properties. It eliminates bacteria and dries out the pimples. Moreover, it reduces the time taken for healing.
How to Use?
- Take white toothpaste only and apply it to the skin infested with pimples.
- Leave it overnight.
13. Aspirin
The anti-inflammatory properties of aspirin reduce the swelling caused due to accumulated pus. It unclogs the pores and removes their moisture.
How to Use?
- Crush the tablet and make a paste out of it by adding water.
- Apply this paste to the pimples and leave it overnight.
14. Aloe vera
Aloe vera is perfect for application on entire face or back. Its anti-inflammatory and antibacterial properties disinfect the skin and reduce its redness and irritation.
How to Use?
- Apply a generous amount all over the affected area.
- Leave it for 10-15 minutes and then rinse it off.
Aloe Vera
15. Lemon
Lemon reduces swelling and also kills the bacteria to heal the skin.
How to Use?
- Using a cotton ball, apply the fresh lemon juice to the affected skin.
Lemon
16. Listerine
This antibacterial mouthwash contains essential oils such as thymol and eucalyptus. Apply on the skin to sterilise or disinfect that part.
How to Use?
- Take some drops of Listerine on a cotton ball and dab it on to your pimples.
- Let it dry. Then rinse it off with water.
17. Cinnamon
Cinnamon is the fastest way to treat acne. It has antimicrobial properties that help heal the pimples.
How to Use?
- Mix 1 tsp cinnamon powder with 1 tsp honey to make a fine paste.
- Wash your face and apply this paste.
18. Egg white
The enzymes in egg white control the excess sebum production and pimple breakouts. It unclogs and dries the pores, and eventually heals them.
How to Use?
- Add lemon juice into egg white and apply it on the face.
- Leave it on for 30 minutes. Rinse with warm water.
Egg White
19. Turmeric
Turmeric is a well-known antiseptic which kills bacteria, treats skin conditions, and helps the skin recover.
How to Use?
- Mix turmeric with water to make a paste and apply it on the pimples.
- Leave it on for 15 minutes and then wash it off.
Turmeric
20. Multani Mitti or Fuller’s Earth
Multani Mitti absorbs excess oil and impurities. It also helps in improving the blood circulations.
How to Use?
- Mix 2 tsp Multani Mitti, 1 tsp rosewater, and 4-5 drops of lemon juice to form a paste.
- Evenly apply the paste on your pimples and wait till the time it dries.
- After 15 minutes, wash it off.
21. Fresh Juice
Make juice out of 8-10 carrots, ½ lemon, 3 peaches, and 3-4 fresh basil leaves.Drink 1 glass of this juice daily. It cleanses the toxins in the body.
22. Yogurt
Yogurt is rich in anti-inflammatory properties. It cleanses and soothes the inflamed skin.
How to Use?
- Apply a layer of yogurt on and around the skin affected with pimples.
- Rinse it off after 15-25 minutes.
Yogurt
23.Neem
Neem leaves are traditionally used as an anti-acne remedy. These leaves are rich in antibacterial, antifungal and blood purifying properties.
How to Use?
- Dry the leaves in sunlight. Crush and grind them to make powder.
- Mix Multani Mitti with 1 tsp neem powder and make its paste by adding some water.
- Apply the paste on your pimples and keep it for some time. Let it dry.
- After 20-25 minutes, rinse it off.
How Can You Prevent Acne?
- To keep your skin pores unclogged, use cold water and wash your face twice a day.
- If this problem is persistent, use cream which contains Salicylic Acid and Benzoyl Peroxide.
- Steam your face regularly. It helps you keep your pores open and remove blackheads and pimples easily.
- Wash your makeup tools such as sponges and brushes regularly to remove oil, dirt, and bacteria from them.
- Do not pick or squeeze pimples. This intensifies the sebum production and can lead to even more pimples.
- Include foods rich in Vitamin A, Vitamin E, Zinc, and Niacin in your diet.
- Regular practice of Yoga for Glowing Skin and exercises is very helpful in preventing pimples.
- Follow a proper skin care routine daily or once in every 2 to 3 days.
- Read these tips for glowing skin.
Pimples are quite common in daily life. It is a way of body to manifest the underlying malfunction. Follow these homemade remedies and tips to have that glowing, healthy and pimple-free skin. However, if you ever get it, treat them immediately to keep your skin flawless. Also, stay hydrated by drinking more of the fluids and eat healthy to sport a beautiful skin.
